I've been offered an 80s Boogie Mark IIB amp as a trade for something I've got on ebay, but know nowt about Boogies (Mesas?) at all. It apparently has a walnut cab and the chap tells me it sounds like a Fender Princeton. It has been converted to 240V and he has had it from new/never gigged/waxes it daily etc.
I'm waiting for fotos, but apparently it looks like
this...
http://i.ebayimg.com/t/Mesa-Boogie-Mark-II-B-Tube-Amplifier-1x12-Combo-Hardwood-Cab-w-Slip-Cover-/00/s/MTAxNlgxMjQ2/z/nIUAAMXQlgtS--4M/$_57.JPG(Which says it is cherry, rather than walnut, but whatever).
Anybody know what they are like or worth come the usual flip in a fortnight's time?
He's in Aberdeen so it will be a postal thing, but he is happy to send his first so I'm not worried about that side of things..
All info gratefully received
They have a lovely, mid-heavy, medium gain singing sustain. People like Larry Carlton used to use them.
Must admit saying it sounded like a Princeton surprised me somewhat..but I've really never tried anything like this and I'm nothing if not curious.
Might be worth a go then, thanks both
The 'difficult to dial in' reputation is a bit over-done in my opinion. If you have the manual, you can be up an running with great tones in no time.
Once you understand how the gain controls interact, they are actually quite straight-forward.
I'd happily have mine back....
Heard they're directional, but I didn't check that. I was just awed by how cool a relic amp looks and sounds - pretty legendary little thing.
I remember a review of one and the tag line was..." Looks like a 1940s wireless set. Sounds like a flying bomb!"
Dave.
1. First and foremost, these amps sound great but are very, very loud. Mine only really started to chime when the master volume got to number 2 on the dial, by which time which ever pub I was playing in was usually in ruins. I once played an open air festival with it, which involved a 15k rig, at which I thought it would be an ideal opportunity to stretch its legs, so I turned it all the way up to 3! Afterwards the sound engineer said he didn't bother using the microphone on it as it was the loudest thing he could hear coming off the stage, even after he'd walked 400 yards back up the hill! I replied, PARDON, WHAT?!!.
2. I found that the best way to use the two channels was to run the clean channel as such and stick a nice transparent OD into it for crunchy rhythm tones, then use the lead channel as a solo boost. You can still download the manual from t'internet I think. Worth a read.
3. The graphic, in my experience, is pretty much integral to the overall sound. I tried playing with it switched out but it just didn't sound meaty enough somehow. It adds a nice fat warmth to the whole thing.
4. There's no getting around it, they are about as heavy as a Boeing 747, flightcased, an Airbus A380. The main reason I sold mine was that my back was taking a bit of a hammering lugging it in and out of the car. Come to think of it, the car took a hammering too... It was worth the effort though - it must have been, I lugged it around for over ten years. The upside of this is that they are utterly bomb proof.
5. If you can, get a matching extension cabinet. It's a fantastic amp to start with but its even better with the extra cab. It sounds less focused and more wide open, if that makes any sense?
Anyways, hope you enjoy it, I'm sure you will.
He was probably still more or less straight inline with it. My DC-5 was like that. I took it to a festival gig in a big indoor venue once and another band's guitarist asked to use it, so I thought it would be a good opportunity to hear what it sounded like out front. I went right to the back of the room next to the mixing desk, and I could still hear the little thing directly from the stage, right over the top of the multi-KW PA. But even a few feet off to the side - luckily including where the sound engineer was standing - it was just 'in the mix' and clearly coming mostly via the PA.
You end up not daring to turn it up to the point where you can hear it because it'll part the audience like the Red Sea in front of it if you do. The only other option is to lie it on its back somewhere behind the drummer.
Ok I'm exaggerating a little, but if you're not careful they will genuinely cut a swathe through a crowd, leaving an area where people just do not want to stand.
It wasn't just my playing either, the two other guys I knew at the time who had them had the same problem, I overheard non-musician audience members say "the guitarist's a bit much isn't he?" on a few occasions.
Use with caution.
if it doesn't work out for you, give me a shout, I dearly miss my early MK...
