Would be like someone who uses the neck pickup getting a Nashville Tele with the neck pickup removed and be forced to use the middle pickup instead - it just wouldn't cut it.
That said I’m sure you’re right and it’s just not crossed my mind with the Ibanez as I’m not looking for it to replace my Les Paul or do the same job. I would say that the HSH configuration on the Jem makes it the most versatile guitar I own in terms of genre but it still won’t nail a strat or Les Paul exactly.
Joe Satriani refused to use 24 fret guitars for a long time and then eventually only used one when it had a single-coil sized humbucker in the neck to minimize the placement issue.
In the end I walked out with the S2 Vela I actually went in to try out. Now there's a guitar you should try if you can...
