Holes for the neck screws?
I've just ordered a Strat Callaham bridge assembly and have been looking through their website at setups and modification tips.
One of the quick and easy mods he recommends is to open up the screw holes on the body of the neck joint so that they don't bite the screws. He says that by opening up these holes you get a better neck to body connection.
Anyone done this or have any concerns about doing it?
  • ICBMICBM Frets: 72942
    Ideally the holes should be exactly the same diameter as the outside of the screw threads, so the screws pass through without any friction.
  • FuengiFuengi Frets: 2850
    That's what he says. I'll drill them out with the correct sized drill bit when I install the bridge / tremolo unit later.
  • paulnb57paulnb57 Frets: 3091
    Go steady when you drill them larger, if the drill bit grabs, it can split the wood along the grain to the open end of the neck socket, ask me how I know......seriously ruins your day!...
  • axisusaxisus Frets: 28353
    That's what I have always done. For one thing it is the logical way to get a tighter fit between body and neck, but it also gives a bit more leeway for adjusting neck position a tad.
  • SteveRobinsonSteveRobinson Frets: 7107
    I find a 4.5mm bit ideal for Fender screws.
  • sweepysweepy Frets: 4212
    Some Fender screws are not threaded along the whole length so it makes no difference for them, I must admit that it’s never been a problem in 40 odd years of guitar tinkering
