ok guys. my mex strat conversion is coming along so it should become a guitar for all sounds type of axe.
I'm going to replace the nut with a graphite job and then set up the neck. using a wilkinson trem at the bottom end set floating and locking tuners.
is the nut replacement and setup relatively easy for the complete beginner. I'm after a guitar that stays in tune when I do some whammy bar abuse albeit not to floyd rose levels. Do you have a link to a sensible step by step instruction set as I don't want to make a hack job of the nut for instance.
or should i just take it to the guitar tech and ask him to fit the nut and set it up?
ta
nick
Do you have nut files? If you don't, and don't want to buy a set (they aren't cheap) I'd get the nut cut by someone with the tools and experience.
The process is challenging the first time you do it. You have to consider
- fretboard / nut radius (therefore you might need a fretboard radius gauge)
- the string gauge you are using (this may determine which file sizes to buy)
Alternatively, a simpler method is to buy a pre-slotted graphtech graphite nut. I don't think they should cost more than 15 pounds and it is pre-slotted already so that you don't have to buy fret files.
Instagram
Even the instructions say that it is a "drop and swap" solution, requiring no slotting whatsoever.
There are tools out there to make it easier for slotting nuts. I use this jig i bought on ebay to help me shape the nut to the proper radius and spacing
Instagram
