Hi
Picked up a nice and cheap 4501 to as a reasonable portable amp for gigs when I can't bring a half stack. I used it for a couple of gigs over the weekend and found the following;
- The amp sounds very bright and even harsh, not much low end and the mids sounds ...hmmm..."honky"
- Ch 1 sounds great when dimed or almost dimed
- Ch 2 sounds very "fizzy" and didn't work that well with pedals in front
The amp seems to loose "ooomph" now and then and I could clearly here comeing and going....odd
I have planned to do the following:
- Service + re-valve. Should I get L6L's or 5881's? or can it be modded for El34's? What's the benefit of this?
- Maybe change the speaker (G12 75) to something a bit "warmer: and "looser" sounding
I understand there are other mod's out there and I'm keen to learn what could help me make the amp sounds less harsh, warmer and Ch2 less fizzy. also looking for good tech in London who can sort the amp out.
Thanks!
thanks for advice and input! think I'll go down the EL34 route.
I love V30's but wil check out the Creambacks.
What do you think of Svetlana Winged C's in the poweramp and JJ ECC's in preamp?
Cheers - very useful!
