The term RMS refers to a constant level signal over a broad(ish) spectrum which music just isn't, so a clean clear undynamic limited signal can be fed into the cone in pulses (music beats) at several times the RMS power for reasonable sustained periods. BUT a raw guitar signal is none of those things and outside of just pootling about gently at home the risks are that a large peak (which the amp can easily pass in excess of that 300w) which will pop the voice coil out of the gap. Or a distorted signal (where the high voltage/current holds the voice coil still so theres little cooling and dissipates the energy as excess heat) will damage the loudspeaker soon enough.
What are the components (make and model) and what are the intended uses.
