If so, what kind of wattage do you reckon a bass amp needs to fill venues smaller than that?
The power needed is a bit difficult to gauge - it depends a lot on the efficiency of the cabinet and the type of amp. At one extreme you have something like a 300W valve Ampeg SVT with an 8x10", which would be capable of overpowering volume in a pub, and at the other something like a 300W 1x10" Class D combo which probably wouldn't be anywhere near enough in the same room.
I would say that an old-school solid-state 150-300W should normally be enough through a 1x15" or a 4x10", maybe a 2x10" although you would want to be at the upper end for that. 500W through anything bigger than a 1x10" should be fine, even if it's Class D.
