Edit: and talking of cheap, the Duncan Designed hot rails in my Jackson sound really good. I believe they're slightly hotter than the SD ones they're based on
then you can have both
I essentially have both on my EMGs with active EQ
What I have tried that is very similar are the Duncan Custom Shop Pearly Gates for Telecaster and for Stratocaster. Both surprisingly LP-ish until around the fourteenth fret, where the screwed in neck loses out to a glued in one for mechanical sustain.
