Mine are more like weeks.
Seriously though, I always double check with the router. When changing bits, I unplug the thing just to make double sure.
It'll all be worth it come stringing up time, that's a great feeling
(formerly customkits)
And yet...dammit...I've done EXACTLY what you did. Plugged in what I thought was a switched off router! Luckily it was on its side on the workbench but I c*****d myself with the surprise and the what might have been
It is a salutary lesson for us all and everyone on the forum should read your post (and also because your build is so cool )
so a bit more progress after work today.
Pte
The inevitable noobie question next.....
I have been thinking a lot about the merits of neck pocket angle versus heel angle.
I want to go with angle on the heel as Neil (Ivison) and Daniels' have suggested - but I'm still umming and aahhing about the best way to go about this.
I thought about trying to mill the angle on the drill press using a surface trim bit. I have an x-y vise for the drill press so I could set things up to mill off a few millimetres on the back of the heel with the neck set at say 3 degrees to get the facet right. Or I could shim up at the nut and use a router sled on a couple of blocks at the right height to get the few mm shaved off.
Or I could try use a block plane etc etc .
By my reckoning with a tenon about 71.5mm long I need to measure about 3.5mm off the end of the heel and shave off that angle. Basic trig - but theory is very different to practice - especially when you've never done it before !
How do others go about it ?
cheers
Pete
... but what I do if I want to make a slope like that on a bit of wood is clamp the thing in a metal-jawed vice so the part I want to get rid of is sticking out, then file down to as close as I dare to the metal without bashing the file, then finish off with coarse abrasive paper on a block until it touches the vice jaws.
Again, I'm sure it's a massive bodge and it does sort of assume that the vice jaws are dead parallel (mine are as near as doesn't matter), but it does get decent results with basic tools.
The neck is resting, fretboard down, on a piece of wood that is hinged at the heel end.
The block of wood between the angled piece and the baseboard is moveable - by moving it left to right, you change the angle at which the neck is resting.
The router rests on top of the two side pieces at the right end of the jig, and then cuts the angle into the base of the heel.
As long as you cut a little at a time, you can trial and error both the angle and the amount of heel that you cut away.
cheers !
Mark's course is full of them. There are normally a few ways of doing most jobs - Mark gives you the simple-but-it-works version for most of them.
Not sure where he's hosting the course now, or what the cost is, but I originally proof-watched it for him on Udemy (and it is still there).
[edit]
Here
https://guitarmaking.co.uk/
cheers
Mark then uses these
To clamp the back of the neck to the bench, but don't clamp it so tight as to damage the back of the neck!
Alternatively, I've got one of these ...
... which I place over the neck, and can then clamp (again, not really tightly!), the bottom of that caul (ie the uppermost surface) to the bench.
I'm a lot better at sharpening and using a hand plane than I used to be, but I'm still not reliable enough to ensure that the heel is completely flat.
Great build, this...
Here are the construction pics if it helps anyone else to build one of these
Onwards ! I now have such a collection of home made jigs that I am going to have to build more than just my dc junior
Nice jig btw! Looks like that'll do the job just fine!
For the neck mortice, I use a 12.7mm profile bit, much like this one: https://www.trenddirectuk.com/46-95x1-4tc
For the neck heel angle, it already looks like you've got that well and truly licked! I have a selection of simple angle jigs of various degree denominations that I use - 1.5 for a Single Cut and 3 for a '59 DC:
(formerly miserneil)
