I've scored a Pedalworx Cactus Crunch OD cheap, only because it has a crackly pot seemingly, but hopefully when it turns up I should be able to sort that fairly easily. Can't find much info on them apart from a single YouTube clip. The Pedalworx site is pretty useless as I think this pedal is discontinued (although it does have a quite fetching image of boobies on the home page, not that any of you will go and check of course).
So, any good? Are they rated? I've not spent much so no bother if it's a pile of poo, just wondering if I've unearthed some super rare boutique gem for peanuts?
@Moe_Zambeek.
Well it arrived today. Opened it up and it's dated as a 2006 build on a 2005 board and the PCB has "BL" handwritten on it. I've got no idea who built it, doesn't seem to tally up with either of the builders' initials you suggested.
I've had a tinker with it and found a couple of faults which were fairly easy to sort out: a broken wire on the output jack and a dodgy input jack which was grounding to the pot next to it (either a bad design or the jack holes have been drilled in the wrong place). A couple of noisy pots will need replacing as they didn't respond to switch cleaner spray very well, but at least it's actually working now. It sounds pretty good, grits up very nicely without getting into major distortion and has a huge amount of level boost. Overall for £20 I'm very happy with it.
