Get an EQ equipped version as it massively adds to the versatility. Mine has the simulclass option.
There is a simple mod to make it a great three channel amp.
Don't discount either! Got the Mark IV long head for c. £800, which is a total bargain given how monstrous its tone is. The Mark V: 25 is wonderful too - if anything, more aggressive, and doesn't at all sound like a small/EL84 amp.
If it were me though, I'd be on the prowl for a decent second hand Mark III/IV head.
JP2Cs come up occasionally, and not always for that much - there was one on here not long ago for c. £1.5k.
I've got a number of Mark amps - but the basic issue with the Mark II / III is that you only get a single good sound out them at a time in the main. Don't get me wrong that sound is generally amazing, the Mark IIC/IIC+ are smother than the Mark III's I've played, mine is a red stripe, but the basic character is pretty much the same.
There are other issues you have to bear in mind for the older amps – you will need volume to get the sound out of them, either that or use an attenuator, I generally find I need to get a Mark II up to 3-4 on the master to get the sound I’m looking for. My Mark III has more gain earlier on but sounds a bit more brittle.
Also, certainly in the mark II’s, the loop is not very good!
The Mark IV and V address almost all of those flaws – I find the control layout on the IV utterly baffling, but it does sound good once you dial it in. The mark V by comparison is very easy to use, mainly as Mesa realised that grouping the controls by channel was the obvious way to do it
I actually found the Mesa DC5, revision b, to be the right amp for me from a gigging stand point, loud and very good on the gain front with a cracking clean channel. I gigged mine for a decade with no issues.
The MkIV fixed some of that interactivity - although combining the bass and mid controls on R1 and R2 is a major problem because the best sounds are with them set very differently - but overall it just doesn't seem to quite have the aggression and clarity of the III.
Give me the choice of any and I'd probably go for either a basic 100W MkI or the all-options MkIII with Simul-Class, GEQ, reverb and a hardwood cabinet - which is actually the very first Mesa/Boogie I ever saw, in Chandler's in 1986...
”Class A” - which as usual isn’t, it’s Class AB triode - has quite different overdrive characteristics as well as a much more effective volume reduction.
I also like the 10W single-ended mode - which actually is Class A! - on the amps that have it.
You can get them for around £500
^ yeah thats the infamous Schumacher 105 transformer - it is used in a lot of Mesa's greatest hits - Mark IIC+ / Mark III / Pre-500 dual rectos.
However it's not in the exports and they sound great so I think as long as a good quality one is used it's not the defining factor in the amp.
If you fancy plunging into the details of it have a look here:
https://forum.grailtone.com/viewtopic.php?t=37443&start=0
If your thinking about the preamp route - I'd get a Studio and have Dennis Marshall or another reliable tech mod it to the IIC+ specs. He did mine and I've A/B'ed it against my IIC+ and I cannot tell the difference through the same power section.
Personally I'd buy a Mark V or a JP-2C - probably the JP-2C since it's got midi
I worked in the US for a bit so I was lucky enough to have access to a lot of more reasonably priced old Mark amps - in the UK they are silly expensive.
