I've been following the postings by @TTony and @PeterC, both
are going to try out Idigbo for a build. So rather than add my experience into
their postings I thought I do a small post on what I found the difference between
Idigbo and Korina.
I've been using Idigbo for over 20 years mainly the building Flying V’s, I have also used it for LP’s and LPJ’s. Whenever I'm asked to make a 58 Korina V I always try to persuade the customer to have it made in Idigbo. There are several reasons for this, firstly 20 odd years ago it was almost impossible to buy Korina in the UK, what was available was generally very heavy. I would estimate a V body made from Korina would be at least 1.5 to 2lb heavier then one made with Idigbo. I should say this is not always the case as you can get Korina that not so heavy now and Idigbo that's heavy, I think it's fair to say that Idigbo is always lighter.
The main differences between the two wood is kind of quantifiable, particularly if you don't believe in tone woods. I think guitars made from Idigbo sound more musical then Korina particularly when played unamplified, but also when amplified.
So @TTony and @PeterC I would have no hesitation whatsoever to recommend Idigbo instead of Korina. Although for authenticity Korina is the wood to use for certain guitars, unfortunately authenticity can stand in the way of using different materials and different building techniques.
A few photos of some Idigbo builds.
2 Korina builds, the telecaster is made from black Korina that was very heavy, the only way to use it was to make a fully chambered F hole Tele, the Strat was also chambered.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Not least because, 60 years ago, that particularly timber was probably chosen because it was available, suitable and affordable, rather than because it had any magical musical properties!!
Mine is still in plank form under one of my benches. It's next on my list of workshop projects though, just as soon as I finish the firebirdbox and a cab or two for the self build amps.
Thanks for the observations Graham.
I have generally found the korina i have had to be a bit prettier,and some of the idigbo to be a bit coarser grained with more pin hole knots,and i have had some with an unpleasant greener tinge.... but that stuff just gets used under paint. There is plenty out there that looks great.
But can we shut up about it so it stays cheap please
Instagram
Must admit I am enjoying the ease with which the Idigbo machines. And its light and has a lovely ring to it so far.
But yes @WezV we want to keep the price down !!
I have quite a bit of it in 8" x 2" wide planks at the moment.
After much deliberation on what to build next after the 2 juniors , I am planning to do two guitars sort of simultaneously :
1) a DC special - so I can do my first 2 pick up guitar . I have all the basic DC templates and jigs now, ready to use.
2) An Idigbo Tele . I saw Rick Kelly's film a few months ago and was inspired by that to build a Tele. I already have a Richie Kotzen Tele which is a beautiful Tele, but its a bit too "bling" for me if I'm honest, and I miss my old Jap plain cream Tele.
So, the plan is to do an Idigbo Tele in a Natural finish - but have a go at binding the body on this one. There a nice Gregor Hilden video I saw on YT where he was selling a master built Korina Tele which had a nice dark brown binding. I think that would look great on Natural Idigbo. I cut the 2 pieces for the blank about an hour ago and have just router planned it ready for jointing.
One question I do have though is.....If I wanted to make a neck with Idgibo should I be thinking about laminating a few pieces and re-sawing, reorienting and gluing up to make a false "quartersawn" neck blank, or is this just plain daft and I should just buy some nice maple ?
cheers
Instagram
When I first read what @flyfisher12 had written I kind of got stuck on how to correct what he had written, politest way would be to say “Should have gone to Specsavers” But I think it should be put in perspective and say it as it is you're talking a load of BULLOCKS
I find it offensive for someone to insinuate that I do not know the difference between Korina ( Limba ) and Idigbo, But I'm not going to make a big thing about it, we've had too many disagreements that I've got totally out of hand on the forum, so I'll just leave it with the comments below.
First of all let's clarify the name Korina, it is some sort of made up name, I believe it's a trade name, or a name Gibson made up in the late 50’s when naming the 58 flying V. Calling it the Limba 58 V doesn't exactly roll off the tongue very well, sounds much better the Korina 58V. I'm sure someone will tell us where the name Korina first originated from, but it is not the real name of Limba. It might have got the name Korina from the local dialect of the country that was cutting the trees.
The name Korina is now accepted as the name of Limba rightly or wrongly so, well I think we can live with that.
Idigbo is a totally different wood, it looks different, it smells different, it machines different and it sounds different, you do not get a black version of it or the lovely colours that you can get with Limba.
https://huckeguitars.com/korina-wood-in-the-uk
Termenilia Superba that gives some pale golden wood, some dark wood, gets lovely orange streaks where bugs tunnel into it
Termenilia Ivorensis that is mostly pale wood, sometimes more greeny or tan colours. Noticeable coarser grain.
They both work well for guitars. The individual piece is more important than the species here
I used to import a few bits of black limba which were perfect, most of the bits I see in the UK now are nowhere near the same quality. Often too heavy with muddier grain. Grey limba if you will
The trade names are ridiculous. You won't easily find either of them called korina outside of the guitar world.
Instagram
(formerly customkits)
My final words.. use and enjoy Idigbo theres way worse to use out there
Most of the Korina/Idigbo/Emeri/Limba guitars I have seen are a lovely natural finish - but I'm not sure of a good approach to getting that right !
The V in the photo that's finished has no colouring it’s just clear polyester, you can get the same finish with any clear lacquer.
