Top row:
Genuine Fender Black Pearl 4-ply USA Standard Strat, 3/8" pots - badly warped, but will flatten out when screwed down - £10
White Pearl 4-ply USA Standard Tele - unused, with film - £15
White Pearl 3-ply vintage Tele - £10
Genuine Fender White Pearl 4-ply USA Standard Strat, 3/8" pots - lightly used but with original packet - £20
Middle row:
Tortoise 4-ply HSS Strat, 3/8" pots - unused, with film - £20
Green-ish 3-ply Strat, 8mm pots - pot locator pin holes - old but still with film - £15
Aged white/cream 3-ply Strat, 3/8" pots - enlarged/damaged neck cutout - £5
Bottom row:
White single-ply Strat, 8mm pots - slightly aged, minor cracks from screw holes to edges - £10
Black single-ply Strat, 8mm pots - mini-toggle hole drilled between switch and pots - £10
Aged cream/coffee-colour 3-ply Left Hand Strat, 8mm pots - £10
All including postage.
Black and white pearl Fender and tortoise HSS Strat ones sold.
Les Paul style: two-layer black/white, £5; three-layer black/white/black - the neck pickup cut-out is damaged (might be best turned into a 3-pickup Custom one), £3; plain cream, £5
Middle row: some sort of semi-acoustic guard probably, two-layer black/white, £5; unused Les Paul backplate, black with brown paper, £3; cream Les Paul with shielding foil on the back, £3
Bottom row: switch covers - the two-screw one at the right matches the cream backplate and also has foil on the back - £2 each.
All including postage. If you need exact dimensions for any of them, please ask.
Unused Les Paul backplate sold.
The top row of cream ones have gold lettering, the middle row darker almost black lettering. The black ones all have gold apart from the one in the middle row which is a sort of flat bronze colour. Most still have their original self-adhesive layer on the back, although I cannot guarantee if it's even still sticky now!
£2 including postage each. Pick one you like .
You certainly may .
Black pearl sold.
