Starting out in recording - Is Audacity recommended?
Audacity gets good reviews on line and looks intuitive to use. Would those with more experience still recommend this as a starting point before I go too far down the road with it?
  • Danny1969Danny1969 Frets: 10517
    Reaper would be a better bet .... it's pretty easy to learn and more than good enough. You can evaluate it for as long as you like ..... I've been evaluating it since @Grunfeld ; told me about it ... about 15 years ago :)
    Thanks, why would you recommend Reaper over Audacity?
  • dogloaddogload Frets: 1495
    Audacity is too limited and I have found it to be a bit of a pain. As far as I remember there is very little flexibility and control over what you are recording. It is useful as a sort of 'audio notepad' and if there is nothing else available, but as a serious recording tool I would go for Reaper.
    Reaper has many of the features available in fully-fledged pro systems at an affordable price!
    That’s good enough for me, thanks for the advice!
    Don't be deterred by the initial learning curve though :)
  • Audacity is primarily an audio editor which can do mulitrack recording. It's a neat little program and has many uses, even add mentioned as a little notepad. Having said that albums have been made on it!
    I'd probably go with Reaper though as a fully fledged DAW with everything you need and a workflow more in line with other daws. If you are on PC then you might want to also look at Sonar (Bandlab as it now is) which is free. On Mac, don't overlook garageband. Good luck
  • KeefyKeefy Frets: 2341
    +1 for Reaper
    edited March 2020
    Once you have spent the time learning Audacity you will find that it's not quite good enough, and then you will have to spend more time learning another DAW such as Reaper.
  • thecolourboxthecolourbox Frets: 9969
    I always use Audacity to record because I find getting Cubase (my main daw) or Reaper (which I'm "evaluating") to work with any of my interface devices is a total pain in the arse. Record easily into that, mix, arrange, as effects etc in a DAW
    soundcloud.com/thecolourbox-1
    edited March 2020
    You need to look into that, as I'm recording flawlessly within seconds with any of my preconfigured templates.
    edited March 2020
    Reaper download page:
    https://www.reaper.fm/download.php
  • SnapSnap Frets: 6266
    Yeah, ditto, shouldn't be a problem.
  • p90foolp90fool Frets: 31869
    If you need to buy an audio interface check those out first. A lot of them come bundled with a cutdown version of Cubase for example, which means you only have to spend time learning one platform instead of switching to it later as you start to take it more seriously.
  • JalapenoJalapeno Frets: 6408
    Reaper, Garageband (on Mac only), or Tracktion/Waveform are my low cost/free recommendations.
    Audacity is a great editor, and a functional single track recorder, but I found it a bit of a faff for multi-tack recording.
    Feedback
    Audacity I use as a standalone primarily for taking MP3 I am learning for the band and changing the key of the song to what the vocalists prefer.
    In the past I custom-made Windows sounds from ripped CDs, my fave being the Smells Like Teen Spirit bass riff when emptying the bin etc.
  • firepaulmusicfirepaulmusic Frets: 368
    edited March 2020
    I should add that I’m intending to use my XR18 as the audio interface, so hopefully all I need to buy is a decent microphone
  • Thanks for all the advice, much appreciated..
  • I’m trying to use Reaper with my Line 6 interface (UX2). I can get it to record but there is around half a second of latency, any ideas? I thought maybe a better interface may be the answer?
    edited March 2020
    You should be able to adjust it in the driver software.
    Preferences > Device > ASIO Configuration (or click in the top right corner)
    Latency between playback of recorded signal as you play ?
     That's normal - there's usually a playback option if you are monitoring through the same interface.
    Feedback
