Inspired by Keefy’s posts about Trainwrecks I was inspired to dig out all the Twreck info I acquired many years ago when I was active on Ampgarage and at that time building a Dumble 50watt clone And corresponding with Scot Lerner and a few other guys who were early into reverse engineering the Dumble.
I had plenty of info on the Express amp but never got round to building one up. Instead I got sidetracked with making a few plexis after the Dumble ODS type amp was finished.
So , with curiosity getting the better of me and keen to have a new self built amp to go with the two juniors I have been making, I have set about making a rough and ready Trainwreck Express type amp - using the famous Francesca as the basic circuit and layout to work from.
I won’t be sticking rigidly to the original build and parts but will be using the same circuit. I’ve built lots of amps and know how to trouble shoot issues with lead dress etc. Some of my quietest amps have looked the messiest in terms of wire runs etc but I know the principles to get an amp sounding good. I am going for 2 x 6v6 output I like 6v6s for their early crunch .
The donor chassis is from an 80s Pro-Amp Viper which i doubt manny people will remember. Pro-amp had quite a nice amp called the VSQ65 which I owned for a while, long gone now.....
The circuit board will be eyelets on 2mm Tufnell whale board / phenolic.
iron is a bit of a challenge cos at the moment although I have a lovely output TX I can use , I only have a couple of spare mains TXs laying around and neither is ideal. One has a 300-0-300 winding but is only 80-90 ma. And the other is has a 450 - 375 - 0 secondary with no centre tap. Both TXs have sufficient 6v and 5v windings to do solid state or valve rectifiers etc . I need to read up Merlin Blencowes excellent book on PSU design and see what I can do to get the B+ in the right ballpark unless anyone has suggestions ? If not I will need to order a new 300-0-300 mains tx.
The donor chassis up to recently had a 5e3 circuit in it and I’ve removed and kept the deluxe board for future use to build another 5e3 quickly in the future sometime.
So having printed the board layout to scale it’s time to start drilling the board and staking in the eyelets, before making up the heart of the amp. Should be fun !
I know the amp will probably be a bugger to get stable but I am looking forward to seeing how this turns out.
Stay well. PeteC
stay well guys and gals
Never played through a Trainwreck either, I've heard they are very dynamic / touch sensitive? My gigging amp for the last 4 years has been a Rosewell Plexi Lite for what its worth..
I still need to find a good mains transformer for this express build though...
I am also building an airbrake to use with it for recording in the little studio attached to the house. Cant risk the cops coming round !!!
Your amp build looks awesome
If you mean with the Express - its finished and waiting to go into a better head cabinet when I buy some decent Cherry.
I need to fit a bright switch as well ( apparently a key ingredient for the Express sound ) but its already pretty bright without it. It will probably boost some freqs though and help the lead sound.
I A/B'd it with my Plexi 50 clone for as long as I dared to in a built up area, and its a great amp if you like classic rock tones - the best thing is how you can play the amp from the volume control of the guitar - sparkly cleans through to searing leads with a twist of the volume control, very expressive.
