Can someone explain it to me?
Based on my past guitar ownership, I believe I've felt most comfortable on a PRS 22 fretter with 9.5 or 10 gauge strings. However, I'm more a Superstrat guy for sounds (SSH) and stylings and now own and play a modified 21 fret Robert Cray hardtail and 22 fret trem-equipped Tyler.
How come the string tension on my guitars always seems taught, making the B and E hard to bend, yet I play similar guitars that belong to friends, and most of those are strung with 10s and even 11s, and there's no issue.
Scale lengths? How many springs on the trem etc but one's a hardtail or how I string my guitars (normal way)??
I'd love to play 10s but 9.5's are fine as long as I can be in standard tuning and have the slinky feel you get when you tune down half a step to Eb.
I pulled the pad away from the nail on my index finger this weekend playing the bendy solos from 'Hotel California'
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
Both guitars are set up well and have had some attention in the last 9 mths. Possibly a better cut/new nut might help, but I don't know about these things and obviously, a luthier casting an eye over them would be good. Alas, my guy for years has been Charlie Chandler but at the moment, I can't get to him due to Covid-19 and he's probably shut.
I just thought I'd see what people's thoughts on it are and your string one is a good start
Incidentally, I use D'addario 9.5s and I've tried the Paradigm and other variants and didn't like them at all. Thomastiks aren't bad.
In terms of tension. If the same make / gauge of strings were used on two guitars of different scale lengths then the tension would be lower on the shorter scale guitar in order to achieve the same pitch. PRS typically have a scale length of 25” vs 25.5” for a Strat.
Tremolo - no real difference. When you bend a string, the bridge does move and the other strings do relax. You do however need to increase the tension on your “sounding“ bending string until it reaches the correct tension to give you the note you are reaching for. And that is constant, whether your bridge is fixed or a tremolo. The amplitude of your string bend (the distance by which you need to bend a string to attain a certain rise of pitch) will however, be higher with a tremolo bridge.
Fret height obviously makes a significant difference, higher frets being easier to bend with. Smooth frets too...
Nut slot height: makes a difference to bends at the lower frets. Place a capo at the first fret - if your guitar is now significantly easier to play, then the nut slots are too high...
Action - measured at the 12 fret, modified most prominently by raising or lowering the bridge/saddles. Even minor adjustments can change perceived string tension dramatically.
Equally, the arc relief - adjusted with the truss rod.
So assuming your nut slots are cut to the perfect height:
1. Start lowering your string saddles, whilst making three and four semitone bends at the 15th fret. Once your bends start ‘choking’ raise the saddles very slightly.
2. Tighten your truss rod (hopefully at the headstock), until you start to get buzz at the lower frets - then loosen very slightly. Plenty of Internet resources how to use your string, fretted at the 1st and 15th frets, as a straight edge.
You’ll then have the optimum set up - for your playing style.
Bottom line: find a good guitar technician who will set up your guitar optimally - for your playing style. Then learn how to tweak / fine tune things to make it absolutely perfect for you.
I hope that makes sense...
DGT had jescar (harder than the Dunlop equivalents) version of 6100, and is a 25” scale length.
Fender Robert Cray (MIM) Tyler Classic (Japan)
Hardtail Gotoh 501 Trem with 3 springs
21 Frets nickel 22 Frets silver nickel
Medium Jumbo Wide Tall
Scale Length 25.5 Scale Length 25.5
Radius 9.5" Radius 9.5"
If I liked the feel of PRS guitars, they're a 25" scale length and usually a 10" radius. Is that .5" in scale length going to make a big difference and be that noticeable?
Other guitars I've really loved the feel of and don't find a tension issue with, even with a thicker gauge set of strings, are EBMM guitars, namely the Albert Lee and Silhouette (HSH) hardtail and they have the same scale length as mine and aren't too dissimilar in other aspects.
Excuse the questions but I don't know much on these type of details and yep. It does need looking at by a luthier
Charlie Chandler knows his stuff and also uses a Plek machine and I'll just have to wait for the more important issue of this pandemic to pass and all to get back to being safe and relatively normal.
Much appreciated
However, the string tension on my 69 Strat fitted with the same strings is noticeably stiffer tension making bending and general fretting a bit harder and for the life of me I can't figure out why. Hardtail can't be the reason because my Telecaster is of course hardtail. But on my 69 strat the 009s on the 69 feel like 10's. (I'm seriously thinking of trying 008s with it.). Action on all my guitars are low.
in fact, I've just measured the scale length on both Strats and the 69 saddle position means it's actually 1/8" shorter than the 2009! Anyone got any thoughts as to why the tension on the 69 is tighter?
(The 69 has 21 frets, the other two have 22 frets - but I can't think that would make any difference as the scale length is the same? )
Yes, I agree. Probably something like neck radius giving a different 'feel', could also be the action. If the strings are the same make and gauge, the scale lengths the same and the guitars tuned to the same pitch then the string tension should be qual across both guitars. It goes to show that there’s more to have a guitar feels than just tension.
Nut slot heights
Fingerboard radius
Fret size / height
Arc relief
Action
..and there may well be more.
http://hyperphysics.phy-astr.gsu.edu/hbase/Waves/string.html
String tension is just a part of what we feel when we fret.
As It was, I was using D'addario 9.5s anyway but had the issue I started this post with and this seems to have done the trick and they feel really good. I didn't like other types like the NYXLs or Paradigm and was going off D'addario's.
The EB's are still priced the same as most strings and there's no higher cost as with some of the aforementioned. I'll see how I get on
