This has caused great controversy over the past years - and probably why no one's responded yet
- By all accounts, the Wudtone trem is a good product and many users are very pleased with them
- There is nothing inherently wrong with the operation of a traditional Fender-type trem if correctly set up and therefore there is no fundamental problem that needs a solution
And that is all I'm going to say on the matter
EDIT: The trem I used instead was a Wilkinson with modern saddles because it was the trem I was used to, and was super comfortable on the Chapman ML-1 I was using at the time. That was set fully floating and never had tuning issues. Here's me using it: https://www.youtube.com/watch?v=-9iDLPaGMO0
The first step was of course to inspect my own tremolo carefully...
I found, on the rear side (saddle side) a 1mm gap between the baseplate and screw dome that allows plenty of tremolo movement without the baseplate fouling against the dome of the screws (please see pictures).
Therefore it seems a waste of time and effort.
https://i.imgur.com/LiwUV43.jpg
https://www.dropbox.com/s/2fmospyy7thwq6e/AriaBridge.mov?dl=0
It confirms what you say:
- the baseplate does not contact the surface of the body.
- it does not contact the dome heads of the tremolo screws (unless you really dive bomb)
