Unlike the body, which looks like a partially-sighted child tried to draw a Rickenbacker...
All that headstock work but they can't carve the nut...
I actually don't mind the shape... it's the sheer Size 15-ness of it I can't get past. I did wonder if they would take the opportunity to reduce it a bit on the new ones - but apparently not. Oddly enough it actually looks slightly more sensible on the bass - but it might just be an optical illusion.
The Godin one is almost as bad as the Anderson though.
I just can't help but love that
It's alright, but still looks like the result of an accident with the belt sander.
On Suhr vs Anderson, I can see what @ICBM means but the Anderson had never really bothered me before. It looks like it's had a bit lopped off the bottom edge, whereas the Suhr looks like it's had a bit lopped off what would've been the round bit on the end of a Fender headstock.
I can't decide if I like the bigger split-level headstock they use on some Suhrs. I think it depends on the colour.
Nil Satis Nisi Optimum
A Dean V also has a 'V' neck profile, so everything matches with the body, bridge and headstock.
Also makes me think of Hagar, who is one of my favourite vocalists.
https://www.guitarplayer.com/.image/t_share/MTYxNDYwMjM3MTM4NjY3NDMy/horus-m3-mf-amethyst-front.jpg
Horribly crude blend between the headstock and neck at the back ... suspect string spacing ... and that ugly routing cutter burn mark in the truss adjuster cavity just scream 'don't give a crap, amateur' building. My eyes didn't even really get to the 'dragon's knob' :-)
It would look fine on a MusicMan Albert Lee - where the normally pretty MM headstock looks equally wrong.
