Strat Pickups - vintage vs high output signal/noise ratio
jaymenonjaymenon Frets: 851
For higher output Stratocaster pickups is the signal-to-noise ratio higher?
i.e. Do you get more signal and the same amount of 50Hz hum? (Which would obviously be a good thing)
Or does the volume of the hum also increase proportionately with the output volume of the pickup?
  • ICBMICBM Frets: 73037
    Generally hum increases. It’s a function of the number of coil windings - to get more output without more hum you need more powerful magnets, like a Duncan Quarterpounder.
  • jaymenonjaymenon Frets: 851
    edited April 2020
    Thanks John - I suspected as much...
    interesting point about the more powerful magnets
