Les Paul Knob Pointers
RaymondLinRaymondLin Frets: 12319
My Gibson strangely never came with one, I found that Thomann sells them (even aged ones), are there anything to look out for when fitting them and removing the knobs?
https://www.thomann.de/gb/gibson_ppkp_059_knob_pointers_nickel.htm
  • johnljohnl Frets: 2011
    Nothing to look out for really - it's a very straightforward process. Take the knob off, put the pointer on, put the knob back on - if the knob doesn't come off easily I tend to use a couple of spoons on top of a towel for leverage.
  • RaymondLinRaymondLin Frets: 12319
    How are they held down in place without spinning?
  • JerkMoansJerkMoans Frets: 9105
    Not an answer to the questions I know, but while these look great, whenever I've had them I ALWAYS end up impaling/tearing chunks out of the ball of my thumb on the things.
    Then, if you'd heard me play, the lack of coordination/dexterity would probably make perfect sense.
    Inactivist Lefty Lawyer
    The pointers? They're held down by the same nut that holds the pot in place.
  • robertyroberty Frets: 10930
    They're cool but they're sharp. I have drawn blood on more than one occasion
  • kossofffankossofffan Frets: 590
    Worth taking the rear cavity plate off before pushing the knobs on, to apply equal pressure to the back of the pot with your thumb to prevent pushing the shaft through the base plate.
    Not that I've done that ;)
    well only once!
  • fretfinderfretfinder Frets: 5222
    edited April 2020
    I believe you can buy them with rounded as opposed to sharp points if you want to remove the gashing risk. Although I’ve been using Gibson’s with sharp pointers for over 30 years and never stabbed myself yet!
    260+ positive trading feedbacks: http://www.thefretboard.co.uk/discussion/57830/
  • ICBMICBM Frets: 74396
    +1. AKA "Thumb Rippers". I would avoid them, personally.
    well only once!
    *Always* take the cover plate off, both to prevent that and to stop the pot turning round and breaking the leg off the tone cap.
    They are tricky to hold in just the right position while you tighten the nut and hold the pot still on the inside.
  • skunkwerxskunkwerx Frets: 7024
    I popped some very low tack (it was masking tape I ran over my t shirt a few times) to indicate where i want the pointer to point on the guitar body. Whilst the knob was still on.
    Removed the knob, undo the nut, hold the back of pot try not to let it move.
    Pop pointer on, pop nut back on, keep holding pot, finger tighten it, then put the knob back on just so it bites the grooves on the shaft to make sure its number still lines up with the pointer, then whilst holding pot from back tighten with spanner.
    Can also just do one knob at a time, eyeballing it per say.
    well only once!
    Well *now* I have to take my cover plate off to see if I've broken anything....
  • RandallFlaggRandallFlagg Frets: 14211
    well only once!
    I pulled the shaft out of a pot on an R8 when trying to get the knob off a while back...much to the mirth of this forum.
    well only once!
    I’m sure your plight was met with sympathy and helpful remedial suggestions, in equal measure.
  • markjmarkj Frets: 944
    Bought my Gibson ones from Amazon. Faber makes them and they’re cheaper.
  • veldt666veldt666 Frets: 83
    I have removed loads of these, "Thumb Rippers", from my Gibson's over the years. P.M me your address & I'll send you some, F.O.C.
    Then again, if anyone wishes to point at a 'Les Paul Knob', I'll PM you details of my next jam sesh.
    Glued to music sell them in Nickel. £1.60 each.
    Thanks, that would be fantastic!
  • robgilmorobgilmo Frets: 3756
    Thanks guys, now Im gassing for pointers, where do you get the none sharp pointy ones?
  • SteveRobinsonSteveRobinson Frets: 7340
    I would say AllParts but they are out of stock of course
    Me too! I’m so bleedin’ suggestible :open_mouth:
