If however you do want to remove all the strings just stick something of the correct thickness between the trem block and body - I have used a pile of picks taped together but you can use wood, coins etc. whatever is solid and of the right size that you have around.
I've used that method when changing gauge or from standard tuning to Eb tuning and it makes it a much quicker process - just restring it and then a couple of turns of the screws to adjust the claw after.
My band, Red For Dissent
The Edge Zero is a bit different to most Ibanez trems - the ZPS system is like a backstop/stabiliser.
If your guitar is the most recent one it is this:
https://ibanez.fandom.com/wiki/ZPS3
The nearest I have is an Edge Zero II on a JEM - this variant can be used with or without the ZPS (I have a JEM with that system that came without). In your situation I would probably remove it - set the system up as per a normal floating trem and then add it back after if you want that feature.
There are pros and cons to a stabiliser in terms of how the system feels to use and behaves. The idea is to help return to pitch and stability, some also like the effect when playing double stop or unison bends being more like a fixed bridge.
The downside is the stiffer feel and it may be harder for subtle effects. A good double locking system stays in tune well without one.
Regarding the bridge being forward though, double check that. I usually set mine up so the base plate is parallel to the guitar body; I'm not sure but I think some of the Ibanez bridges have a wedge-shaped baseplate, so they look like they're pulled forward when they're not
