If so, clamp that end of the guitar down with the headstock hanging over the other end. Bend the neck downwards/backwards - that will release some of the tension on the rod and make it easier to turn the nut if the main problem is friction against the adjuster plate.
If the nut has rusted onto the rod that's more difficult, although it still may help to free it. You could try squirting a *small* amount of WD-40 into the hole - don't overdo it and saturate the wood.
You might be surprised how much force you need to apply to break or strip a truss rod too - don't be afraid of using quite a lot of effort. If you can't get the short end of the Allen key to reach, use the long end and put a piece of tubing over the short end to give you more leverage.
I dont have the equipment, but i can grab a helper.
I'll add some WD40 and try that first.
The only way i could put more force on it is if i put some bodyweight into it
https://en.wikipedia.org/wiki/Penetrating_oil
AFAIK
apply some, then leave the guitar in the position where some might flow by gravity down into the locked threads
Another option is heat or cold, depending on which piece of metal you can apply it to, the outer or inner
That's what it was originally intended for, yes - that doesn't mean it doesn't have a host of other uses.
After giving it an injection of WD40 and literally putting some body weight into the allen key, it turned! Stiff as all hell but a lot better now and turning.
I'm surprised at just how much force i had to put into the bugger to get it moving. I had to wrap a sock around the allen key to stop it cutting into my hand!
