Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Edit: sorry I thought this one I mentioned was bench mountable.
The thickest you might need for most building (excluding resawing) is about 4". Mine does that on mahogany just fine, but needs to be well setup with a fresh blade if I'm trying it on maple
I would love a bigger/better saw, but it's managed to do everything I need it to for at least 15 years.
I actually have a spare similar model anyone can have if they can collect from Burton. It's tires needed replacing but I think I have those too, or can point you in the right direction. It's not quite as sturdy as the older model, but free to a good home
Instagram
- do you have experience of that saw ?
that Axminster model ac1950b seems to get very good reviews , probably has enough grunt for what I need and will fit nicely in the shed. Also within budget so I could buy some extra blades and mitre fence too. The larger model is too big - though I'd love a bandsaw with an 8" depth of cut !
I will probably bite the bullet and order one this week. Knowing how impatient I am probably just too late to cut the Tele bodies I have started making at the mo !
Ive just ordered the 1950B; i also bought a Titan last week, but the fence isnt good Enough.
Love the vidEo support from Axminster.
blade for tight curves and template making.
