Yeah - I know.... This isn't for me by the way. I have a mate who wants to setup a very cheap arrangement to record jam sessions. He wants to use a mixer with four mic inputs and four instrument inputs to output to a monitor so they can hear themselves and to a laptop / phone / whatever to record the results. I have impressed upon him the large bodge-factor in this arrangement and have tried to push him down the JamHub route or similar but he's having none of it. So...... as you know, little mixers jump in price once you go past two mic inputs. My question is - if he uses XLR to quarter-inch adapters, and plugs a mic into an instrument input on the mixer - will he hear anything at all - or are the signal levels and impedances so incompatible, it just won't work. My logic here is, in trying to keep the cost to an absolute minimum, a mixer with 2 mic inputs and six instrument level ones is cheaper than a 4 mic input mixer. I also have to make sure the thing has a separate mono channel for each input - trying to use the often included stereo channels to take two instruments and juggle the pan knob etc isn't going to work for him.
Offset "(Emp) - a little heavy on the hyperbole."
You need a preamp to amplify the microphone.
You could use a DI to go the other way (instrument into a mic input) there is no way to amplify a microphone to a decent level without a mic preamp.
How cheap does he need a mixer ... you know you can get a 12 channel digital mixer with direct out recording on multiple channel for £230
If the signals loud enough he can use a mic into a line input .... that's the main difference, the available gain
https://twitter.com/spark240
Reddit r/newmusicreview
£150 tops.
So, forget all ideas of anything sensible..... it's just a case of 'will it make a noise' !
I've been looking at used Behringer X18 and X16 analogue units. I'm wondering if it might even be cheaper and easier to get two really small units, like the 802's and merge the buggers.
I can do it for him, but it'll be shit and clunky and crappy fidelity - but there you go.
