@RaymondLin, does it buzz at only one spesific 12th fret or does it buzz all over the fret above 12th fret? If it is only at the 12th fret, probably there is an uneven fret?
If all above 12th frets are buzzing..this is a sign of too much relief..if this is the case, it is reasonable to adjust the truss rod..
It's the latter, it buzzes on a few frets hence i am thinking adjusting it. It doesn't buzz on open string.
