I loved valve amps up until:
1. This thread was created.
2. I found out about all those legendary SS amps.
3. I discovered I'm an angry little man.
My Class D developed an intermittent fault, which I traced to the bridge rectifier being used to create a DC supply for the heaters in the valve preamp - so that’s a solid state component in the valve section of a solid-state-powered amp.
I have no idea what conclusion to draw from that, but with any luck anyone with an inclination to argue can find something in it to support their argument.
Have at it!
This was recorded with nothing but the er40, a behringer distortion and a diy fuzz face for the lead.
The problem with digital is that regardless of the build quality, if a custom chip fails and the manufacturer has no spares, that is game over.
'cos, you know, diode clipping in a tiny little box is a good thing but diode clipping in a much bigger box is a bad thing. Or something.
More recently I took the plunge on a well-priced Fender Tonemaster Twin Reverb (yes, a modelling amp) and have found it to be a far more useful studio/home amp than any valve amp I've owned. Most of the time I'm using it muted via the XLR / IR into my interface/monitors and it's as good a sound as I could ever need. With a nice OD in front I'm happy as Larry and I don't find myself fantasising about the perfect "Plexi sound at bedroom levels" tube amp that everybody seems to want.
I also expect it to make my gigging life much easier on bigger stages next year (Stones tribute) where I need something large, punchy and authentic-looking. No road case required either - it weighs as much as a Princeton. We don't know about long-term reliability of these yet, but if all else fails it's a very nice lightweight 2x12 cab with good speakers and a standard size Fender chassis, so there'll always be *something* to put in there that'll make a sound. I don't think you could say the same about the Katanas etc.
I did pick up one of the new AC10s on a whim earlier this year, but I can't really see it getting a lot of use if I'm honest now.
Trading feedback here
One the one hand, its a modelling amp that can only do one thing, which seemingly defeats the point of using modelling tech.
On the other hand, I'd be willing to bet that actually a lot of people who do use modelling tech end up only using one of the available models anyway, so maybe making the active decision to dedicate a modeller to exactly one type of amp isn't all that crazy.
Certainly the weight and extra features make one hugely appealing. If they can nail the sound then all the people (myself included) who've ever said "I want a Twin but I can't deal with the weight" may end up putting their money where their mouth is.
Though it's technically a modelling amp, I don't think of it in that way. From a user point of view, it's simply a great sounding clean amp that's supremely easy to live with. I bought it with the thought that I could easily send it back if I didn't like it, but after a lengthy ABC test with the AC10 and a DRRI I found the Tonemaster won on all counts - including basic tone when wound up to healthy levels (to my ears at least - others may disagree). I know for sure that playing along to tracks on my monitors via the IR out, this thing sounds like a very well recorded Twin Reverb in a mix, and that's good enough for what I need.
Tube amps will remain. I don't see Mayer swapping out his Dumbles anytime soon.
That is of course, only if SS amp don't make a come back.... after all bass players used them, and they are known for great tone. Also Chappers can make one sound like a tube amp and he can make a tube amp sound like a bee in a tin can, so they must be good.
It's not a case of being loyal to one or other amp type, it's just a matter of the right tool for the job. Hence I have 3 traditional valve amps, plus a digital modelling and a solid state amp that are both hybrids ie with a valve or two that are used differently in each.
I like to have choice.
http://www.thefretboard.co.uk/discussion/57632/
A friend of mine has a solidstate 300 watt Peavey bass head from 1974 that's done 10 thousand gigs or more. I've repaired a couple of minor things such as the sockets which wore out and a couple of pots but it's still essentially the same amp it was nearly 50 years ago. Believe me none of the current crop of class D bass amps will get near that lifespan
As you mention a class D bass amp has to be insanely rated to sound even close to as loud as a linear 100 to 300 watt model. Some of the models are woefully underpowered and only suited to small gigs or need a lot of PA reinforcement.,
My old Peavey Century 100W Class AB/linear solid-state bass amp was almost as loud as my 500W SMPS/Class D Promethean too.
Sorted.
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
I suspect the cost of 'servicing' a 50 year old helix will give you a nasty shock in years to come. ;-)
I much prefer my helix amp models, but the problem is they are a bit too good and make everyone else self conscious so I tend to jsut use the FX from the helix into the vale amp jsut to amke everyone more comfortable.
TBH the only reason I have 3 valve heads is because I feel I should do other guitarists a favour and remove some of these shitty sounding anachronisms from general circulation.
Especially my diezel - i wouldnt wish that on anyone.
