Repairing a ding in poly finish
noisepolluternoisepolluter Frets: 820
Is there a way to repair this ding in black gloss poly finish? It’s just less than a cm long, and has made a slight dimple in the poly as well as the mark which you can just detect with a fingernail.
Would the mark likely polish out?
https://flic.kr/p/2j7jp7V
  • SargeSarge Frets: 2433
    Black nail varnish drop fill, really thin coats a day apart until it is proud of the body, scrape it back when fully cured with a new Stanley blade, put masking tape either side of the blade leaving a gap the width of the scar.
    Then a few grades of wet and dry paper and polish to finish.
    Or black superglue if you can find it, same process as above.
    This has worked great for me many times.
  • TINMAN82TINMAN82 Frets: 1846
    Would totally leave that myself. But I do like relics.
  • JalapenoJalapeno Frets: 6415
    Before you start a drop fill & bodge it to buggery - try the soldering iron and damp rag trick
    Feedback
  • noisepolluternoisepolluter Frets: 820
    Full disclosure - I did this, it’s the first ding, and it’s Esther’s guitar. *hangs head in shame*
    Hmmm I’ve used that on an unfinished fretboard edge to good effect but I’d worry the hot iron will cloud up the poly irreversibly.
    That only really works well if there's exposed wood, the point is to rehydrate the wood fibers which will swell, I can't see the op pic clearly on my phone but it doesn't look like it broke through to the wood?
  • mrkbmrkb Frets: 7037
    Put a sticker over it.
    Karma......
    Ebay mark7777_1
    I'm doing a few drop fills with superglue right now, this thread got me off my arse and into action on this beater Westone.
  • SteveRobinsonSteveRobinson Frets: 7122
    I say don't touch it. You can easily make it much worse.
    Just fess up and ask forgiveness.
    Looks like a good advert for leaving well alone.
    4reaction image LOL 1reaction image Wow! 1reaction image Wisdom
    I think it’s just dented and marked the top coat - it’s not made it through to undercoat (if there is one) or wood.
  • AdeyAdey Frets: 2425
    edited May 2020
    Just needs a scrape back and polish. You won't notice them after that.
    I've snagged 2 good t-shirts on that gouge and don't fancy a third.
    These pics are all wet glue, not exactly the finished article
    I’d be interested is seeing the process you use to flatten/polish the glue and the finished result.
    Karma......
    Ebay mark7777_1
    Same process as the stewmac video posted above, I'll post pics tomorrow when I've finished if I remember.
  • DefaultMDefaultM Frets: 7427
    Have you heard of gas lighting? It's great, just tell her she did it herself and if she suggests it was you tell her she's gone mad.
