Why does my B string sound like a sitar???
I recently changed the strings on my PRS SE 245 to a slightly heavier gauge (9s to 10s). I’ve got it set up as best I can in terms of action / truss rod etc, but the B string seems to have a strange subtle sitarish sound ( best way I can describe it!).
Does anyone have any idea what would be causing this?
  • VJIvesVJIves Frets: 466
    I just got a new Reverend that has the exact same issue with the G. It's so weird.
  • pinching in the nut?
    Bye!
  • dtrdtr Frets: 1037
    The saddle of a sitar is a flat block that the string vibrates against, rather than an 'edge' that the string is in minimal contact with.  When a string has a sitar-y tone, it's often a miscut nut or saddle that leaves too much of the string having a flat contact.  If it's this you should be able to hear which end is the problem and get the relevant one (saddle or nut) recut/replaced.
  • Thanks for the replies. It’s a PRS wrap around one piece bridge so there’s no saddles!
    So if it’s the nut how hard of a DIY job would it be to fix?
    Ah, probably the bridge then.  Wraparounds can make those kind of noises  Some folks like them for it..
    So do I just have to live with it lol?
  • ICBMICBM Frets: 73056
    Does it do it on all the fretted notes, or just the open string? If it only does it on the open string it's the nut, if it's on the fretted notes it's the bridge.
    It’s all notes!
    Crazyblue1779 said:
    It’s all notes!
    It's the bridge then. It's probably been indented by the previous 11-gauge string, so the new 13-gauge is sitting on the 'burrs' that have been formed along the sides of the groove.
    Loosen the string completely so you can get at the groove, and run the tip of a craft knife blade along it - be careful not to slip and scratch the top of the bridge. That can sometimes be enough to fix it.
  • SeshSesh Frets: 1885
    A g string will do that.
    Can't sing, can't dance, can handle a guitar a little.
    14reaction image LOL 1reaction image Wow! 0reaction image Wisdom
  • guitars4youguitars4you Frets: 14783
    ICBM said:
    Crazyblue1779 said:
    It’s all notes!
    agree it sounds like a rough seat for the string to sit in - Might harm the finish a touch, but sometimes  double side some wet /n/ dry and clean to and fro through the string gap to clear up any rough edges - Worse case a thin round file like a top nut file and clean through the slot gently - Not only to clean the slot/groove and not make deeper/larger
  • sounds like fret buzz to me
