Tone control on single knob Superstrat
SunDevilSunDevil Frets: 511
I fancy giving something with a Floyd a go and I’m Gassing for a Friedman Cali, but I just can’t see me getting on with a guitar with only a volume control?
I don't tend to ride the tone that much - really gets set for a particular amp / room and stays there
Assume I could use a double-stacked / concentric pot but is there any better way to do it on a rear routed, single knob guitar?
  • DrBobDrBob Frets: 3021
    Or,if you’re a “set & forget” kind of guy maybe a mini trim pot that’s accessible through a hole in the back plate ?
  • p90foolp90fool Frets: 31925
    Or maybe a cap and resistor on a push pull pot?
  • stickyfiddlestickyfiddle Frets: 27723
    edited June 2020
    ^^ thos were my first 2 instincts. I'd have thought a push-push pot with a preset "6/10" setting would work a treat. Or even combine the ideas and have a push-push/pull volume that goes to a trimpot & cap so you can have full flexibility
  • ICBMICBM Frets: 73033
    If it gets set for a room, just make a passive ‘tone box’ and put it first in line after the guitar. You could even make it into a pedal with a footswitch to bypass it if you want.
