Fender AVRI Jaguar - 11s
Squier VM Jaguar HH (Danelectro-style fixed bridge) - 10s
from what has been said, it looks like 12's may be a step too far for my digits so I will fit a set of 11's.
Thanks for the input all.
(If you bend at a different fret than the 12th then that 1/2" bend increases the length more, but the 12th is the easy one to calculate as it's in the middle).
So how does that 0.085% or 0.075% stretch translate to an increase in pitch? That 1/2" bend raises the pitch by a semitone or so, depending on the string and the guitar, which is about a 6% increase.
(I can do the maths, it's just the physics I can't handle at all!)
There are numerous mechanical and acoustic properties which heavily influence the resultant pitch from a string bend. Analysis of the physics of string bending suggests that the resultant pitch of a string bent at its midpoint is given by
where L is the length of the vibrating element, T is the tension of the string prior to bending, θ is the bend angle, E is the Young's Modulus of the string material, A is the string cross sectional area and
is the linear density of the string material.
Thus, the pitch is not only dependent on the bend angle, but on material properties of the string such as Young's modulus; this may be interpreted as a measure of the stiffness of the string. The force required to bend a string at its midpoint to a given angle θ is given by
I haven't messed with neck shims, but I think that the larger strings and Mustang bridge may have made the shims unnecessary. I have tried a tip I saw online to tape one leg of the bridge to stop it rattling. It seems to stop any rattle and as I don't use the term a great deal I will see if it stays or not.
Anyway, now it is done I quick picture albeit not able to get it outside due to the rain. I have to say that it seems a great buy for £320 and some new strings.
https://i.imgur.com/FfnyFTS.jpg
