I posted (way back in September 2018!) about my desire for a Micawber-esque telecaster, and came to the conclusion that a partscaster build was the best way to achieve it. I got as far as getting a body and neck from Guitarbuild, and sent the body to
@Iamf68 for painting, and had a bit of a chat with
@Alegree about pickups... and then life got in the way. I'm now determined to get this finished!
What I have so far is this:
I have a good local luthier, Steve Kendall, waiting for me to deliver everything to him to build it up. The point of this thread is to make sure I've got everything I need, and to make a few decisions about various parts. I'm not making a faithful replica of Micawber; this is to be a modern take on the idea. I want those Brown Sugar/Start Me Up tones, but it would be good if it were more flexible than that. I think I'll go with nickel hardware across the board. So:
Tuners: I'd like locking, and I see there's a set of Fender/Schaller lockers in the classifieds. Any reason not to go for those?
Do I need a string tree with this set-up, or is the stagger in the Schallers enough?
Nut: I am intrigued by the idea of the earvana. Is it specifically for regular tuning or will it help for a guitar that's going to be tuned to open G? If not the earvana, then just a bog standard bone nut?
Bridge: oh gods I've just spent I don't know how long reading about brass vs steel tele saddles and bridges! I definitely want six-saddle (the low E saddle will be removed). The string holes are 54mm, which I think means vintage spec rather than modern spec? Does a Kluson contemporary bridge look like the right idea here?
Ferrules and neck plates and control plates - is there really much to pick from here, or are they all just much of a muchness?
Pickups & electronics: I am pretty set on Alegree's Chameleon in the neck and a Cirrostratus in the bridge. Alex tells me this can be wired up with the tone control acting as a blend between the pickups, and the pickup selector actually picking the three modes of the Chameleon, with a push-pull on the vol knob for hot/regular. So when it comes to controls, I guess I need a standard tele three-way switch, and two pots, one push-pull. Are there 'better' and 'worse' brands for me to aim for here? I'm assuming Steve will have all the caps, resistors and whatnot needed.
Pickguard - one ply black. Is there any reason not to get a simple cheap plastic guard? I see I can pay lots of money for bakelite.
Electroplate socket seems to be the best? It's got a 22mm socket rout.
Strap lugs - I think I'll use this as the excuse to fit straplocks across my collection - Schaller S seem to be the industry standard?
What have I missed?
And how thick is the metal of the armadillo bridge plate? Looks >2mm to me.
