I was after a bit of advice. I have this old Hofner Congress.
When I got it it was refinished. I haven't a clue what it's finished in other than it's clear. As you can see the veneer has been sanded through in a couple of spots.
The headstock veneer had split into several pieces so I made one up from ABS plastic, glued it on and put a vinyl logo on it, then sprayed it with some clear lacquer. I think it's passable. It's got Grovers on it and an old hard case. I'm not sure of the brand, it looks a bit like a Hiscox to me but I don't know a lot about these things. Anyway what I'm wondering is what you think it's worth?
![](src)
https://photos.app.goo.gl/Ukk5kgSi27CsX5vn9Any thoughts are appreciated.
The case isn’t a Hiscox - I remember them with that distinctive ridge down the middle, but I can’t remember the brand name.
I think the guitar will still sell for a similar amount whether it's unstrung with no tailpiece no case, strung with a new tailpiece no case, or as is with everything together. May as well split and get a bit extra
Instagram
The tailpiece is definitely likely to attract the most buyers on its own.
