Guitar hanger alternative or method?
sev112sev112 Frets: 2861
i need to hang another guitar, but the only space is directly above the light switch.
which occurs to me has an electric cable running upwards behind the plasterboard to link to the central light in the ceiling.
so drilling for a couple of plasterboard fixings doesn’t sound like a good idea to me.  Wondering whether a wide / long timber batter with No More Nails will stick to plasterboard and hold the wait of a guitar
On the only other wall available, there are two double electric sockets.  My presumption (1St floor room) is that they don’t run upwards from there.
my alternative is to buy the Hercules 3 guitar stand (already have 2 guitars on the floor, hence wanting to get the new one up on a wall) but that will take up lots of room
any other suggestions ?
  • grungebobgrungebob Frets: 3379
    Don’t use no nails to fix the Batton. I’d fix the batton to the wall studs either side of the socket if possible then fix the hanger to the batton.
  • sev112sev112 Frets: 2861
    Good thinking Batman - although in this case (because of a wall return) I think there will only be one stud, or even one.  But that’s good thinking, thanks
  • barnstormbarnstorm Frets: 643
    Might not work for you, especially if your house is full of small people who bump into things a lot, but I love the Planet Waves guitar rest, which takes up no floor space at all. You just plonk it on a shelf or on your amp and it stops the guitar from falling over. Cheap as chips and nitro-safe, as well.
  • sofastevesofasteve Frets: 39
    Is there going to be sufficient space to hang a guitar above the light switch?
    Yep, tested that :) good to check though
  • hubobuloushubobulous Frets: 2372
    Do you have a picture rail? If so, get the ones that hang off that. I've used them for years and they're solid
  • steersteer Frets: 1220
    I assume you definitely know that the electric cables are there? You can get one of those testers to check.
    Well they do look pretty expensive for one guitar hanger when I looked
  • maltingsaudiomaltingsaudio Frets: 3177
    Not that it helps but I use leather straps which go over the machine heads and form a loop above the headstock, means only have to put I hook ie one hole in
    www.maltingsaudio.co.uk
  • FunkfingersFunkfingers Frets: 14793
    Guitar Hangar?
    You are Harry Seven and I claim my five Guineas.
  • TheMarlinTheMarlin Frets: 8152
    I have a few horizontal hangers in my office.
    Bit like this:
    There some on eBay for £20. Not difficult to fit.
    Bit like this:
    Oh I like that, a lot !  Thanks
