Nickel or gold plating?
Snot-coloured plastic key, or metal? If snot-coloured, how many rings at the bases of the key - one or two?
Nut on the front collar, or a plain small metal ring?
Depending on the answer I probably have one... Gibson have used most or all these variations at one time or another, and I can't remember about 2014.
While they lasted they were great tuners but no longer made unfortunately.
I have some (both sides) in my spares box.
Don't blame your son by the way - the reason we have these as spares is because they so commonly break, often with the smallest knock. Gibson have used so many versions of them that matching them isn't always easy (even discounting different amounts of tarnish on the nickel), and often the best thing for the customer is to fit a whole new set. I will then buy back the other five to keep for other customers!
Unfortunately there is no other type of tuner that exactly fits both the mounting holes and the bore diameter - there are several varieties of these, made by two or three different manufacturers, but they all share the same construction and all can break.
All I can say is thank God for Norlin and their unfashionable maple necks
And since that day I have never, ever picked up a guitar case without checking that the latches were closed. You only get that lucky once.
