I've got a weird static sound coming through on a new SG tribute (open coil 490s and PCB board) when I play chords. It doesn't happen straight away but eventually starts. I get it when I play in the middle position (clean, so that I can hear the issue) and it will go if I change pickup. However it returns again back in the middle position. Have a listen to the clip as this shows that.
It's definitely the guitar, as my Tele doesn't do it. I've tried different amps and a different cable straight into said amps.
What do you think it might be? Faulty pickups or wiring? Some kind of static charge? I don't get any static from the pickgaurd but I do a get a bit from the control cavity cover. Enough to result in this though?
weird.
The PCB itself isn't the problem with these guitars, it's the connectors. I fixed one with random crackling and cutting-out noises perfectly by doing this...
If your guitar has the newer black plastic block pots, you need to connect the pickup grounds to the oval eyelets on the PCB instead of the pot casings.
Here is my controls cavity. The input jack is not on the PCB.
http://i.imgur.com/Nezl7zk.jpg
http://www.thefretboard.co.uk/discussion/57632/
So on the bridge pickup you connect the red and black together and tape off, the bare wire and the green to ground, and the white to the volume pot terminal. On the neck pickup you connect the white and green together, the bare and black to ground, and the red to the pot terminal.
Also solder the bridge ground wire to the pot casing closest to it.
By the back of the pot I mean the back of the metal pot casing.
Ground is any available ground, the easiest are the pot casings.
Bridge:
Bare and green to back of a pot casing.
White to (which terminal/lug) on the bridge volume?
Neck:
Bare and black to back of a pot casing.
Red to (which terminal/lug) on the neck volume?
