FS: Warmoth alder Tele-style body with HB bridge SOLD!
This
1990s Warmoth Alder T-style body has played hundreds of gigs and has
worn accordingly with several paint chips and also buckle rash on the
rear. Pickup cavities were routed for maximum versatility: It can be
fitted with a Tele or Strat neck pickup, Strat middle pickup and
full-size humbucking bridge pickup. Using a standard Tele pickguard the
middle pickup cavity would be hidden and a Tele pickup would be used at
the neck position. Included in the sale is a WD Music pickguard that may
be used as a template to adapt any standard Tele pickguard to accept
two Strat pickups.
The body is fitted with a very good quality chromed 6-saddle bridge to accept a standard full-size humbucker*. Please
note that if this bridge was replaced with a standard Tele bridge the
ends of the pickup cavity would show each side because a humbucker
cavity is longer than a standard bridge width. A chromed jack socket and string ferrules are also provided. No other hardware is included.
* Coil-tapping a bridge humbucker could simulate a standard Tele bridge pickup depending on the humbucker specs.
£110 with payment by PPG, bank transfer or cash on collection. I can arrange insured delivery within mainland UK for £15 or it can be
collected from Kent. I'm happy to drive a reasonable distance to meet part way
if it helps.
Included pickguard can be used as a template for positioning neck and middle Strat pickups in any other pickguard.
