The serial number is an odd one with the 8 so someone more knowledge can decode that - could be a reference to the neck? But the 13 and hollow birds would give as a 2013 custom 22 non 10 top so it's likely to have a wide fat neck with hfs and vb pickups but you would need to see the paperwork or guitar to know for sure.
custserv@prsguitars.com
Just sold a McCarty (also non-10) with rosewood neck for about the same.
My band, Red For Dissent
hope that helps
@Funkfingers is spot on. It’s likely a wide/fat neck profile (most RW models I’ve seen are), and should have Dragon II pickups unless it was a special order or modified later.
The spec’s nice though, and should be a relatively straightforward sale for £1,600-1,800
