Anyone used an iRig 2 with an iPad?
I was contemplating picking up a tiny desktop amp ( Blackstar Fly 3 or similar) for ( shockingly enough) putting on my desk so I could noodle while the the family are otherwise occupying where I'd usually play.
But seeing as this would exclusively be used with headphones, I then though maybe the likes of the iRig 2 ( just the analogue one, not the HD 2) might be a more useful ( and cheaper ) option, especially as I have the iPad sitting on the aforementioned desk.
Has anyone here used the iRig 2? Is it worth the £30 odd quid it would cost?
  • chrisj1602chrisj1602 Frets: 4076
    I use the original iRig with my iPad and it works fine.
  • droflufdrofluf Frets: 3911
    I’ve got an iRig (the original version not the 2) that I used with an iPad that I used with headphones.
    Did the job perfectly although, depending what effects you wanted to use, you may find the inbuilt ones limited.
    I also used it with Mooer’s GE Labs software.
  • Danny1969Danny1969 Frets: 10606
    Yes, iPad mini using iRig to run Jamup ... that aps got amps, effects, 8 track recorder, drum machine, sampler so bit more useful than a BS Fly
  • duotoneduotone Frets: 1024
    Have you given GarageBand a try?
  • grungebobgrungebob Frets: 3379
    edited June 2020
    I use one with GarageBand and Bias amp works well.  Also use JamUp and you can edit/import the amps from bias amp into it.
  • Good stuff! One has been ordered!
  • guitargeek62guitargeek62 Frets: 4258
    Cancel the order and buy my irig HD2 for £40 ;)
  • Cancel the order and buy my irig HD2 for £40 ;)
    Actually? Well ok!
