Some people prefer to stick with the original neck and middle tone controls with none on the bridge pickup. If you do that and use separate tone caps for the two pickups, with each directly wired to its tone control, then you can auto-split the humbucker.
If you never use the tone control on the middle pickup (or never use the middle pickup alone) then you can have separate 500K/.022uF and 250K/.047uF tone controls for the bridge and neck pickups, *and* auto-split the humbucker.
Does any of that make sense?
