Boss CE-2 Chorus.
robgilmorobgilmo Frets: 3495
So, I fancy a Chorus pedal, new to them but loving what they can do ive been looking into Boss pedals, Analogue seems to be the way to go? and ive seen CE-2 pedals all over the Bay, they seem simple enough things with just rate and depth to play with which is good because Im not a big fan of never ending tweaking.
So, any views on these pedals?
  • vizviz Frets: 10699
    edited July 2020
    Lovely things. Try and get a Keeley modded one if you can. It feels like a cow chewing long wet green grass.
  • robgilmorobgilmo Frets: 3495
    Thats in Merica, what does the Keely mod do?
    Im seeing the CE-2W Waza for around the same price, maybe a little more expensive, apparently analogue and close to the same circuitry, is there much of a muchness between the two?
  • RedlesterRedlester Frets: 1072
    The CE-2 is in my opinion a very special pedal. I used to play through an old 80s one (borrowed, sadly!) and then had a Denelectro Cool Cat version 1 which sounded very close.
    My current chorus is a Boss Super Chorus, which I probably prefer because it doesn’t get too extreme, and has tone  and level controlS. It can get very chimey and is sort of a less is more pedal. I don’t go too mad with chorus and don’t use it that much, so the Super Chorus fits the bill for me as someone after something subtle to lend a guitar part a little edge or space.
    By contrast the CE-2 to my ears is a ‘creamier’ chorus- rich and thick! Also it’s warmer.
    A pal once showed me the old CE-2 ‘rate all the way down, depth all the way up’ trick. Divine!
    Don’t know about the Kelley mod. The current CE-2 Waza looks great with the extra modes.
  • nonesuchnonesuch Frets: 308
    I think for a first chorus pedal I'd go for something less specialised and one that can produce a wider range of sounds. (And one that's a lot cheaper than a Boss CE-2.)
     Maybe the Boss CE-5 or CH-1? I haven't actually used one, but the CE-5 Chorus Ensemble could be a good choice - and it's got level and tone controls that the CE-2 doesn't have. I think they are both digital, but I wouldn't be too worried about that. Although I'm sure early versions of the CE-5 are actually analogue.
    I use an MXR Analog Chorus which is great, and it features similar high and low cut tone controls like the CE-5. I usually roll off some of the lower frequencies to give it a brighter, less mid range sound.
  • webrthomsonwebrthomson Frets: 1031
    I've got a Analogueman modded CE2 - amazing thing - I would recommend :)
    Recently got a Thorpy Deep Oggin - also amazing - more knobs than the CE2 though
  • Recently been on a bit of a chorus trip, myself. I tried a Free The Tone Tri Avatar Chorus and in the end stuck with my Boss CE-2, it's the best out there as far as I'm concerned. Last year I bought a DC-2W and that sounded sublime, but again, for my tastes, I stuck with the CE-2. So a couple have come and gone but the CE-2 sticks around and does its job admirably, it's a beautiful sound.
    I have recently bought a Lehle Parallel SW II so that I can mix the chorus into the dry signal, to taste. It's a bit sweeter if you can manage to mix it somehow.
    I keep reading on how they dont like to be run with a power supply unless its a daisy chain? Is 9v too much for them?
  • pigfacepigface Frets: 213
    In my gigging days I used a Boss Super Chorus (CH-1), always on. Simple, great sound, indestructible. And cheap.
  • Jonathanthomas83Jonathanthomas83 Frets: 3471
    edited July 2020
    I run mine 12v, I hate commenting on power requirements because I'm scared stiff of blowing things myself and would hate to give out wrong info. But a kind sir on here told me to run 12v DC and it worked fine. Gigrig do the ACA OK adapter to convert your 9v to the correct voltage too.
  • FunkfingersFunkfingers Frets: 14455
    I can not live with the background hiss of the CE-2. My brother has the same circuit built into his ancient Roland BN-100 bass amplifier and loves it.
    For minimal control tweaking, investigate the DC-2 or DC-2w Dimension C. The CE-20 does a digital version of this. The original Roland Dimension D is still the best.
  • DrJazzTapDrJazzTap Frets: 2168
    I had a Taiwanese CE-2, got it modded with a Keeley style mod. Did sound better not as muddy, keep a look out for an Ibanez CSL, i managed to snag one for £10 on ebay a few years ago. The Royal Mail managed to loose it, when I sold it on.
  • UnclePsychosisUnclePsychosis Frets: 12907
    Easiest explanation is to read this:
    https://stinkfoot.se/archives/726
    It is not a particularly big deal, there's easy workarounds.
  • althyalthy Frets: 92
    edited July 2020
    any chorus by boss is a great pedal.
    The CE-5 I find very versatile and faithfull to the CE-2 tone.
    The CE-3 sucks too much tone if not in parallel but it is very similar sounding to the CE-2 as well.
    CH-1 and Dimension C are also brilliant pedals with the former being particularly good with dirty amps and the later great for a 90's jangly arpeggio tone
    Edit: If you're in for more boutique-y pedals as well the Dr Scientist Cosmichorus ( any version ) is to me the most gorgeous sounding one, hands down.
  • I've genuinely not noticed any hiss on my CE-2.
  • John_PJohn_P Frets: 2750
    Love my old ce2.    As said above just daisy chain it for 9V or run it on 12V and your good to go.   Same for any old boss pedals.
    I used to have a ibanez cs9 that i bought in 85 and an old dc2 and wish I had kept them both as they were also special.
    If you want new then the wazza version are probably fine and I'm there probably are modern chorus pedals that are good but I won't bother when those older ones are so good.
    a ce2 mij just pop on facebook for 95 quid
    Got a link?
  • JezWyndJezWynd Frets: 6081
    Recently scored an Applause Super Chorus. Boss style case (though nearly twice as heavy). It has the CE-3 chip but sounds more like the CE-2 to my ears (though I have neither presently to A/B against). It's a fabulous chorus, esp with drive pedals  or POG, really fattens up the effect. There are a few budget brands from the 80's which are pretty much clones of the CE-2 and they are considerably less coin.
    They are ACA pedals, which require 12 v external power or a 9 v battery internally. You can run them on a 9 v daisy chain provided there’s a newer PSA pedal also in the chain.
  • Winny_PoohWinny_Pooh Frets: 7771
    CE-3 sounds 95% the same for half the price, I used to have a CE-2, CE-3 & JC-77 at the same time.
