I know this is going to be a contentious issue and I also understand that Multi-FX units aren't going to give you godly tone in general but I'm looking for a multi-FX unit on a low to mid level budget.
I just play at home and rather than having a few pedals and getting caught up in the wires etc I'd like decent sounding multi-FX.
Now the TC Electronic Nova system springs to mind but at £300 it's kind of hitting my budget limit. I might sell my Vox Lil NT head and cab to recoup some funds but I'm generally looking around £200 tops if possible!
Would also like it to put a backing track through it if I can and maybe a patch editor?
I've used a POD HD 500 but I couldn't really get on with it, maybe it just clashed with my amp but I just found it a little overwhelming too with all it's layouts and features.
Maybe I'm asking too much?
Opinions appreciated!
Zoom G3.
Only multi I've liked, but I prefer stompies, so sold it
Second hand, you can get the g7.1ut. That's slightly older generation tech though so I don't know how it sounds...
I have a Digitech RP500 which I'd heartily recommend. Very easy to tweak, even live. Having said that, the Zoom G3 or G3X sound great from what I've heard, although if you need/ want pitch-shift effects, the Digitech does this a lot better. I have the MS70-CDR which has a lot of the same modulation models as the G3 and it sounds great.
The G3 is ok but I found the quality of the Nova System effects much better.
If I wanted something now I'd go for:
Nova sys but with a midi pedal to sort the switching out.
Line 6 pod xtlive - turn off the amp sims and use for fx and they sound fine with plenty of fx options.
Yamaha DG stomp - I still have one, very very easy to use and sounds great - not many of them still around but I wish they would reisssue them with 4 patches per bank and a noise gate.
