Getting the right set of strings for an Epi Viola Bass
althyalthy Frets: 92
Hello, I am looking for a medium scale set of strings that wound be good for D Standard tuning ( DGCF)
My bass is an Epiphone Viola and I have my eyes on the Labella black nylon .60/ .115 but I have read that these are actually lighter than their gauge suggests du to being flatwound?
Also the E-string being 115 will that make it more difficult to fit into the tailpiece without filing it?
Many thanks
  • ICBMICBM Frets: 72514
    They are lighter than the gauges would suggest, because nylon is much less dense than steel.
    I fitted a set to a violin bass copy recently and had to do a bit of work on the nut grooves to get them to fit, but the tailpiece was fine.
  • althyalthy Frets: 92
    Thanks! Do you reckon they would be suitable for d-standard?
  • KoaKoa Frets: 120
    Rotosound Trubass are supposed to be what McCartney used on his Hofner ...the roof top gig and Abbey Road. Decent tension should stand D tuning, Hofner 500/1 needs medium scale not sure about Epi
    I don't see why not. The tension is only a bit lower.
    Great. In doubt I went for the FM M. They are stainless steel flats, they should do the trick
    Thanks for the input :)
