Hi everyone,
I've been searching for a drive pedal that gets close to the Mesa studio pre/calibre .22 combo. They deliver a nice, thick midrange with lots of harmonic content. I know there are lots of pedals out there claiming to do the MB thing but it tends to emulate rectifiers which I'm not interested in.
A Joyo JF14 American Sound got me close with mids and voice dimed to the right and I tried boosting with an Empress Para Eq/Boss OD1 and the California Sound but it doesn't get the harmonics quite singing in the way I want without lifting the noise floor.
I've already tried the following:
Joyo California Sound - too dark sounding
Mesa Throttle Box - too fizzy, not enough harmonics
Mesa V Twin - probably closest of all the pedals I've tried but just way too big for my board and it needs a 1300mA 9v supply.
Mooer 008 MkIII simulation - not tight enough
I haven't tried the Mooer 017 yet. AMT stuff seems to be heading off in the direction of a Rectifier.
Am I missing anything at this point in time? H&K for example?
[This space for rent]
The V-Twin is basically a Rectifier in a box, the V1 is a Caliber in a box. I used one when my main amp was a Dual Caliber, in case I wasn’t using my own amp. It is still almost as big as the V-Twin and uses the same 12VAC supply though.
Likewise of the Mesa solid-state pedals you want the Flux Drive not the Throttle Box, although you might find it doesn’t have as much gain as you need.
Although to be honest I don't like the switches on them anyway.
I've been nursing an obsession with Def Leppard this week and very nearly bought a Marshall JMP-1 as well as scouted for a 9004 pre. But I decided to try my existing pedals first and discovered the plex-eq on my Amptweaker Tight Rock gets me close with only some wide, shallow chorus and 500m/s delay needed from a Zoom G3X I have kicking around (not part of my main board). So moral of the story, make the most of what y'got before jonesing for something you might not need!
But what do you plug it into?
And why not just buy a mesa?
Interestingly I got one of the best sounds I’ve ever had with it into a Fender Princeton Chorus.
Have to be honest though, if I was located somewhere I could sell the Burman and Princeton Reverb easily, I would probably get a Calibre .22.
I’m also lazy and hate carrying spare equipment I don’t need, or even any if there’s an amp available, so I’ve always been willing to compromise slightly if it means I can get out of carrying another heavy box... I’ve literally never taken a spare amp to a gig, ever - but always had something (usually a pedal) I can use through anything else if I have to.
FWIW I've never found a pedal (or modeller) that sounds anything like my mesa .50 caliber
