Quandary....
Had it for years. This is one of my two Tele's which gets a lot of playtime.....I like a lot about it - the Soft V neck, S1 switching, but there's other things I'm not so fond of - I have hankered after a Rosewood neck, it's a little bit of a boat anchor @ 9lbs or so and the thick poly finish isn't exactly attractive. However, back to the quandary.....I changed the original 5-hole single ply scratch plate which had warped for an 8-hole WBW jobby which I thought improved it's looks.....but after a year or so has created a crack in the finish.
Nothing I can't live with at all..........except is it telling me to have a poly peel off and nitro refin? ...although what do I do about the neck?
Any more learned folks out there who can advise...to peel or not to peel?.....certainly wouldn't undertake it myself, so I'd be looking for someone who has the skills.
I've read stories of uncovering multiple piece not so great wood under the poly.....so naturally a little dubious.
"There's things I want, there's things I think I want
There's things I've had, there's things I wanna have"
Though if the guitar is a “keeper” and sounds/plays better than its original price tag suggests, then it is probably worth doing. Even if it is a five-piece body, any imperfections can be mostly concealed by a good refinisher.
One thing you could do - especially if the weight bothers you but you like everything else - is get a spare body and have that finished in nitro with a colour you like. It likely won't cost more than strip/refin and that way you have the option of returning the guitar back to stock any time.
A body in the 1.8-2kg range should shave off nearly a pound and half total I would think.
Will it make a difference to the sound? That's a different matter
For what it's worth I went that route with a mexi 60s strat I loved but was also heavy and with a thiiiick early 2000s poly shell. Was very pleased with the result - the guitarbuild body is lighter, 2-piece, with much much nicer contours and the whole thing sounds great.
here’s mine:
since those pics were taken I’ve ditched the s1 switching and replaced the god awful standard pickups with some mojo ‘59’s.
great guitar now and my backup for gigs!!!!
His looked great
i used a can of white blonde and a can of light tint from @SteveRobinson iirc...
Redid the neck a couple of times...
here it is as of now:
JM build | Pedalboard plans
Before;
After; I think six thin coats of tru-oil and a gentle sand of the back of the neck with a fine sanding sponge. Smooth as anything now.
• Youtube - https://www.youtube.com/@Goldeneraguitars
It's a very fine thought that is never far from my mind....cheers for the GAS.
just to try to end on a positive note, your guitar looks wonderful as it is.
