A bit of Sunday night, slightly off the beaten track Yamaha guitar stuff.
Thought I would share this one, as something a bit different from 41 years ago. I have had this one for 3 years or so now, having always wanted another one since I owned one back in 1980/81.
I must admit that when I came across this, I was not expecting a fairly pristine guitar in the original case, with no changes to electrics etc. but I struck lucky.
The Yamaha SC1200 was released about the same time as the SG2000 was started to gain traction as a serious alternative to the Les Paul. Pretty much like the SG2000 and the LP, Yamaha went after the Fender side of things with an attempt to design something with a twist that might appeal.
In the case of the SC1200, that meant a
5 piece through neck ( Fender C shape profile)
Ebony board with pearl inlays
3 blade single coils ( hotter than typical at the time, but very responsive to height settings, can be sweet or gritty )
mini switches for each pick up ( one 2way , two 3 way)
The switching gets a bit silly having the ability to have every pick up combination in or out of phase.
The in phase options are great allowing all the usual settings plus neck and bridge ( very mid position tele ) and all three pick ups.
One weird quirk with using two pick ups out of phase, the right amp settings and a good touch, it's not far away from a Peter Green tone ( bearing in mind these are hot single coils)
You can turn everything off unless you are very careful ( I used one of these live back in the day. I really do not remember how I managed on stage at that time
Playability and soundwise, it's fantastic.
For what I paid for it, it's a lot of fun. A strat type guitar with through neck construction, and ebony board etc, would probably be a pretty penny now and a custom job. Nice to be able to find stuff like this coming up on the market every now and then.
Here are a few photos to put it in context
<a href="
https://imgur.com/5JbVi1K"><img src="
https://i.imgur.com/5JbVi1K.jpg" title="source: imgur.com" /></a>
<a href="
https://imgur.com/9rcvhxX"><img src="
https://i.imgur.com/9rcvhxX.jpg" title="source: imgur.com" /></a>
<a href="
https://imgur.com/FPaOe5x"><img src="
https://i.imgur.com/FPaOe5x.jpg" title="source: imgur.com" /></a>
The thru' neck, or jam sand which approach as I called it at the time, was a popular feature in the early 80's
A good looking example there @artiebear
Edited to add that SC1200 were pretty thin on the ground having only been produced between 79-81. I have seen very few over the years.
Looking at it now, the shape is very similar to the BB basses which I think they still make.
Sod the market value, just enjoy them
Regarding catalogues, wow, how much we relied on them. I recently found the Yamaha 1983 guitar catalogue amongst the guitar mags ( huge stack dating from late 70's onwards ). It was the only way to get spec on anything and lovely colour pictures to look at.
If I ever find a nice Aria PE1500, I will struggle not to succumb. I use one circa 1984/85, I should have kept it.
The only one I actually bought is an Aria CS-400, as seen in this ad with Danny Johnson:
I also had 2 Washburn Falcons, one of which got damaged beyond repair. I always fancied an Eagle after seeing John Goodsall playing one with Brand X
I did a gig supporting Nottingham Indie band Six.By Seven about 13 years ago and their guitarist had a original white Yamaha Superflighter SF500 along with a 60’s Gibson SG. But the only Yam SC I’ve seen was one of those weird offset ones in a pawnbrokers in Leeds about twenty years ago. It wasn’t in a great state as I recall.
I actually ended up going American - a Hamer Special which I got for the princely sum of £250. I got my Aria many years later.
These ones? I like the shape, I remember drawing an imaginary custom guitar for myself and I used that body shape.
The SF (Super Flighter) models were more Gibson SG spec with a thin body, with no maple top, all mahogany and coil tap option (neat little push button) on a couple of models - I'm pretty certain the same p/ups as the SG models when they ran along side each other in the late 70's and early 80's
SF's are maybe another one of those forgotten gems from that era. It was very comfy on a strap and had some great tones.
I also remember sideways glances I got when turning up for work with lovely shiny Yamahas when other string playing members of the band at the time, only played things from before 1960 with Gibson on the headstock (even the bass player was a fan of Gibson EB basses). I guess, for some, it was still hard to accept that these Japanese guitars were any good
