Hi friends,
Has anyone here tried Omi Roasted Coffee before? Basically coffee that isn't specifically roasted for one type of brewing? I drink both espresso and V60 at home and currently haven't found a good blend that does them both well. Currently I'm using quite a dark roast which is great for espresso, and alright for V60 but it could taste so much better.
I know that I could just focus on one method of brewing more than the other, but I prefer black coffee brewed with a V60 whereas the wife prefers latte's with syrups.
I've only come across omni roast recently after a friend recommended it? Has anyone tried it and had good success?
How dark roast are you, what grinder do you use, what flavours do you enjoy?
I generally like v60s on the more balanced, acidic, fruity, funky, floral flavours - Ethiopians, Guatemalans etc. For espresso, I liked a more chocolatey or fudge flavour - Colombian el suarez if single origin, but often I liked rave fudge blend.
The rave Colombian is available as both a filter blend and espresso blend, so you could subscribe to get both and enjoy a cherry-cocoa filter with a more cocoa focused espresso from two different roast levels.
I'm outraged!
