Got any tips for bevelling the edge of a pickguard?
I've just shaped and fitted one, but it's a bit thick so could do with a bevelled edge. I would guess that it is something that is pretty easy to bugger up, so just wondering if anyone has a technique?
  • SteveRobinsonSteveRobinson Frets: 7125
    A router table and 45° bit
  • FunkfingersFunkfingers Frets: 14762
    Some vintage Fender ‘guards had a shallower angle, presumably to show more of the white/black/white border around the red/brown faux tortoiseshell.
    Yes 60° if you can find a suitable bit
  • WezVWezV Frets: 16960
    Yeah  router and bit if you have the template for the guard.
    You can do it with a file and scrapers, but its a 10 second job with the right router bit
  • JeremiahJeremiah Frets: 641
    When I did mine I used a rotary grinder tool - basically a very cheap copy of a Dremel. It worked well enough even for someone with no building skills but took quite a while.
  • andy_kandy_k Frets: 829
    Patience, and a half round file, and then some sandpaper.
    It could take an hour or so, which might be cheaper than the above methods.
  • phil_bphil_b Frets: 2011
    for I one off I would agree with this. a router is quick but also easy to mess up. one slip and it is easy to ruin the pickguard
  • TJT1979TJT1979 Frets: 190
    File to remove the bulk, followed by a stanley knife blade used as a scraper.
    This works for me too.
