Tuning regular guitars to C standard?
Creed_ClicksCreed_Clicks Frets: 1550
edited October 2020 in Guitar
I've tuned to D standard and droppped to E to dropped D (dropped C officially) and guitar held tuning well. I am thinking of going the whole hog, and tuning to C standard. I was going to do it to either a Squier strat or pick up an Epi flying V next year and do it to that.
Flying V would have a shorter scale right?
With a heavy guage set of strings, tuning down, in theory should be ok. I tuned to D using regular guage stings, so imagine a heavier guage would be fine...?
If I had the V, I'd play mainly clean as well, just to screw with people's idea of what a V should sound like...
  • Nick13Nick13 Frets: 736
    12 to 60 will give you a similar feel to 10s in E
  • I tune to drop C. My guitars now are Fender scale and I use 10-52; when I was gigging all my guitars were 24.75" scale and I used 11s with no problem, so as @Nick1 13 said, 12s should be fine
  • Not a V but Hendrix playing clean in C-Standard,
    If you tune to D using regular strings then 11s would probably be thick enough, I'd go with 12's though
  • I use Earny Ball Mamouth Slinky 12-62 in c standard on my flying V. sounds the business.
  • Thanks for confirming folks !
  • SassafrasSassafras Frets: 30358
    I never get tired of that clip.
    Bloody love it!
  • TTBZTTBZ Frets: 3001
    edited October 2020
    11-54 are good for me on my SG in either drop C or C standard. I don't like loads of tension in my strings though, just enough to keep them in tune is ideal. I like 10-52 on a Fender scale for drop C.
  • Yeah the less tension the better so maybe I should try 11s to start with
  • 11s feel good on my SG when tuned right down.
    Trading feedback info here
    My band, Red For Dissent
  • or go the whole hog and get a Baritone guitar. B is only a semitone off what you're going for.
    I sometimes think, therefore I am intermittent
    True. Don’t need to spend a lot so could get a baritone neck and stick it on a squier ...
  • 12-56's in drop c feel like 10's in standard for me. If playing in this tuning permanently I'd consider using a 60 gauge on the low string as most of the work is on the lowest string.
  • ICBMICBM Frets: 74484
    If you use 10s in standard E, 12s will be right for C - 13s for B. If you think about it you already have a 13 tuned to B... it’s just in the second string position :). The only change you need to make is the width of the nut grooves
