In my ongoing quest to learn the basics of guitar repair I bought a new Tusq nut for my LTD EC256 as I’m putting lighter strings on it.
I got the old nut off ok but the new one (pre cut) is slightly too low and the strings hit the first fret. To be fair the frets are pretty chunky on LTDs though.
I tried shimming it with a slice of credit card but it was too high. I’ve currently stuck a couple of thin bits of cardboard underneath which has raise it to what seems an appropriate height, but obviously this isn’t a permanent solution.
Is there any (easily available) material that’s recommended for this type of thing?
Instagram
https://hazeguitars.com/blog/repairing-nuts-with-superglue-and-baking-soda
I think maybe the paper and super glue idea might work best and I could gradually build the layers up until it’s just right.
The nut slot is the correct height when the string just clears the first fret by a knat's whisker, when fretted at the 3rd.
You should set the nut height totally independent of any other set-up measurements. Do the nut first, then neck relief ... then bridge/saddle height to set your action
Instagram
