Can be bought new for around £100.
Demeter Compulator
EHX BlackFinger
Boss CS3
MXR Super Comp
Pigtronix Philosophers Tone
Rothwell Love Squeeze
It kinda depends what you want the compressor to do, but I like it to even the notes out and also drive the front of the amp if I need it. Of the ones I've used the Black Finger probably sounded the best, but it's huge, noisey and needed its own special power supply. The CS3 kinda strangles your low end, but I think it sounds very musical and defo has a thing that it does. I like the tone control on it too. The MXR Super Comp just wasn't very good. On guitar or bass. The Pigtronix sounds really great, has tons of compresion and sustain on tap and you can add grit, but it's a bit noisey. The Demeter is an excellent all-rounder, though you could hear it working at very high settings. Sounded lovely though, and I only sold it becuase I had to. The Rothwell Love Squeeze is a total winner. It's quiet and very tranparent. Not that expensive either. Also sounds great on bass.
I'm always meaning to pick up an ED-1. They pop up for nothing all the time.
Noise, randomness, ballistic uncertainty.
I have the compact version
I went through the same thing as OP, settled on the Barber.
I think I want another compressor too but am confused as to which way to go. I want it to do 3 things:
1) Work well for compressing funk-style chords
2) Give me sweet, long sustain - think David Gilmour style clean leads
3) Be fairly transparent tonally.
I don't want to spend a fortune and am quite happy going used. I've already got a Block logo Dyna Comp and a Biyang Compress X (which I prefer to the MXR as it is less noisy) but I have to set the compression/ sustain level low to avoid them being too squishy which means the sustain isn't as good as I'd like. I'm thinking I should be looking at either an optical comp, like the Demeter Compulator (used) or perhaps something with a blend control. I like the size of the Xotic SP but not sure how controllable it is. Mooer Yellow Comp might be worth a look too.
What say you?
Check it out here. It appears about 12mins in :-
And the Mooer Yellow is superb way beyond what one might think it "should" be at that price point and in that small a space.
My go to recommendation is the visual sound, but that's based on a dyna comp and Ross comp I think? Anyway, it's probably a bit too similar - the exotic will give you a completely different type and is known for being transparent enough to be always on. For funky squish, you could use the biyang
Maybe the Pigtronix Philosopher's Tone will float your boat? (certainly does mine!)
http://www.youtube.com/watch?v=boHgwq5AIHQ
http://www.youtube.com/watch?v=UIyBtVrMqVw
I used to have Dyna Comp and I loved it, although I feel it drops volume.
Also I would highly recommend BBE Sonic Stomp, which is not comp, but does great trick
